Sony xm-zr604 Amfi Alıcam Yardım !
  • Konuyu Başlatan Konuyu Başlatan Renault
Renault
JBL GT5-12 1100W 30cm subwoofer'ımda kullandığım Harward marka amfiyi 3 senenin sonunda güzelce yaktım :):) Şimdi Bu SONY marka amfiyi almaya karar verdim..Sizlerinde yorumunu bekliyorum
  • [FONT=arial,helvetica,sans-serif]110W x 4 Max Power into 4 Ohms[/FONT]
  • [FONT=arial,helvetica,sans-serif]150W x 2 (at 2 Ohms) + 300W x1 (at 4 Ohms) Max Power[/FONT]
  • [FONT=arial,helvetica,sans-serif]60W x 2 RMS into 4 Ohms[/FONT]
  • [FONT=arial,helvetica,sans-serif]65W x 4 RMS into 2 Ohms[/FONT]
  • [FONT=arial,helvetica,sans-serif]High Level Sensing Power On[/FONT]
  • [FONT=arial,helvetica,sans-serif]80Hz High Pass filter with -12dB/Octave Slope[/FONT]
  • [FONT=arial,helvetica,sans-serif]80Hz Low Pass Filter with -18dB/Octave Slope[/FONT]
  • [FONT=arial,helvetica,sans-serif]MOSFET Power Supply[/FONT]
  • [FONT=arial,helvetica,sans-serif]RCA & speaker level inputs[/FONT]
  • [FONT=arial,helvetica,sans-serif]Line level thru-put[/FONT]
  • [FONT=arial,helvetica,sans-serif]CEA-2006 Power Compliant[/FONT]
[FONT=arial,helvetica,sans-serif]Output Power:[/FONT]
  • [FONT=arial,helvetica,sans-serif]CEA Rating: 60W x 4[/FONT]
  • [FONT=arial,helvetica,sans-serif]DIN 45500 Rating (@ 14 V, THD 0.5 %)[/FONT]
  • [FONT=arial,helvetica,sans-serif]4 ohm: 4 x 60W[/FONT]
  • [FONT=arial,helvetica,sans-serif]2 ohm: 4 x 65W[/FONT]
  • [FONT=arial,helvetica,sans-serif]Rated/THD (@ 14.4 V, 20 Hz - 20 kHz)[/FONT]
  • [FONT=arial,helvetica,sans-serif]4 ohm: 4 x 60W / 1.0% (14.4V, 20 - 20kHz)[/FONT]
  • [FONT=arial,helvetica,sans-serif]2 ohm: 4 x 65W / 0.1% (14.4V, 20 - 20kHz)[/FONT]
  • [FONT=arial,helvetica,sans-serif]Maximum (@ 14.4 V)[/FONT]
  • [FONT=arial,helvetica,sans-serif]4 ohm: 4 x 110W[/FONT]
  • [FONT=arial,helvetica,sans-serif]2 ohm: 4 x 150W[/FONT]
[FONT=arial,helvetica,sans-serif]Input:[/FONT]
  • [FONT=arial,helvetica,sans-serif]Low Pass Filter: 80Hz[/FONT]
  • [FONT=arial,helvetica,sans-serif]LPF Roll Off Rate: -18dB/oct[/FONT]
  • [FONT=arial,helvetica,sans-serif]Subsonic High Pass Filter :: 80Hz[/FONT]
  • [FONT=arial,helvetica,sans-serif]Input sensitivity: 0.3 - 6Volts[/FONT]
[FONT=arial,helvetica,sans-serif]Output:[/FONT]
  • [FONT=arial,helvetica,sans-serif]Frequency Response: 5Hz - 50kHz[/FONT]
  • [FONT=arial,helvetica,sans-serif]Tolerance: +0 / -3dB[/FONT]
  • [FONT=arial,helvetica,sans-serif]Total Harmonic Distortion (@1 kHz): 0.005%[/FONT]
  • [FONT=arial,helvetica,sans-serif]CEA SN Ratio: 97dB[/FONT]
  • [FONT=arial,helvetica,sans-serif]Min Load Impedance/Ch: 2 ohm[/FONT]
[FONT=arial,helvetica,sans-serif]General:[/FONT]
  • [FONT=arial,helvetica,sans-serif]Current drain (@ Rated Power - 4?): 33 Amps (at 4 ohm)[/FONT]
  • [FONT=arial,helvetica,sans-serif]Weight (approx.)(kg): 3.1[/FONT]
  • [FONT=arial,helvetica,sans-serif]Dimensions (WxHxD in mm) approx: 396x55x256[/FONT]
Neyde kulanıcan bunu?
Bu mono anfi değil köprüleme ile belki güc alabilirsin ama düğmesi varmı acaba monoya cevrilebilen
bunun hakkı 2 tane 800 lük bastır ama millet genelde 2 tane 1200lük baglar oda bir sekilde calar ama amfi baya bir ısnır yuksek seslerde
60x4 wattır bu diger verilere aldanmayın
teknik spefikasyonlarda verilen değerler 14.4 volt üzerinden verilmiş araclarımızda ortalama 12 volt elektrik olduğu için yazılan değerlere göre bir miktar düşme olucaktır bu anfinin 2 kanalını köprüleyip kullanabılırsın buda sana yaklasık 100 watllık guc olrak gerı donecektır 100 watt lık bır guc subwoofer ıcın yeterlı değil bence
işi prosedüre uygun yapmak ıstıyorsan alacağın anfının gucu subwoofer ın rms gucunden yuzde 50 daha fazla olmalıdır 200 watt rms bır subwoofer kullanıcaksan 300 watt rms anfi kullanman gerekli ama butce olarakda bıraz genıs olmak gerekıyor
eğer sadece subwoofer bağlayacaksan jbl gt5 a3001 mono anfi almanı tavsiye ederim 4 ohm da 175 watt lık bu anfı ısını guzelce gorur
ben sadece jbl gt5-12 1100w 275 rms subwoofer besliycem..Uygunmudur rahatlıkla beslermi
120-140 arası para verebilirim ancak şuanda bütçem buna müsait
Güncel
