Facebook hesabın varsa oraya herkese açık olarak yükle ve resmi kopyalayıp buraya yapıştır.
Bu arada aracın 140 değil 150 HP ve faz1 veya faz2 si yok, hepsi aynı...
[TABLE="class: carData rightT, width: 1"]
[TR="class: b1"]
[TD]Brand[/TD]
[TD="width: 60%"]
Renault[/TD]
[/TR]
[TR="class: b0"]
[TD]Model[/TD]
[TD]
Laguna[/TD]
[/TR]
[TR="class: b1"]
[TD]Generation[/TD]
[TD]
Laguna II Grandtour[/TD]
[/TR]
[TR="class: b0"]
[TD]Engine[/TD]
[TD]
2.2 dCi (150 Hp)
[/TD]
[/TR]
[TR="class: b1"]
[TD]Doors[/TD]
[TD]
5
[/TD]
[/TR]
[TR="class: b0"]
[TD]Power[/TD]
[TD]
150 hp
[/TD]
[/TR]
[TR="class: b1"]
[TD]Maximum speed[/TD]
[TD]
212 (205) km/h
[/TD]
[/TR]
[TR="class: b0"]
[TD]Acceleration from standstill to 100 km/h[/TD]
[TD]
10 (11) sec
[/TD]
[/TR]
[TR="class: b1"]
[TD]Fuel tank volume[/TD]
[TD]
70 l
[/TD]
[/TR]
[TR="class: b0"]
[TD]Year of putting into production[/TD]
[TD]
2002 year
[/TD]
[/TR]
[TR="class: b1"]
[TD]Year of stopping production[/TD]
[TD]
2007 year
[/TD]
[/TR]
[TR="class: b0"]
[TD]Coupe type[/TD]
[TD]
Combi
[/TD]
[/TR]
[TR="class: b1"]
[TD]Seats[/TD]
[TD]
5
[/TD]
[/TR]
[TR="class: b0"]
[TD]Length[/TD]
[TD]
4695 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Width[/TD]
[TD]
1772 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Height[/TD]
[TD]
1443 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Wheelbase[/TD]
[TD]
2740 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Front track[/TD]
[TD]
1525 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Rear (Back) track[/TD]
[TD]
1480 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Minimum volume of Luggage (trunk)[/TD]
[TD]
475 l
[/TD]
[/TR]
[TR="class: b1"]
[TD]Maximum amount of Luggage (trunk)[/TD]
[TD]
1500 l
[/TD]
[/TR]
[TR="class: b0"]
[TD]Position of engine[/TD]
[TD]
Front, transversely
[/TD]
[/TR]
[TR="class: b1"]
[TD]Volume of engine[/TD]
[TD]
2188 cm[SUP]3[/SUP]
[/TD]
[/TR]
[TR="class: b0"]
[TD]Max power in[/TD]
[TD]
4000 rpm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Torque[/TD]
[TD]
320/1750 Nm
[/TD]
[/TR]
[TR="class: b0"]
[TD]Fuel System[/TD]
[TD]
Diesel Commonrail
[/TD]
[/TR]
[TR="class: b1"]
[TD]Turbine[/TD]
[TD]
Turbocharging
[/TD]
[/TR]
[TR="class: b0"]
[TD]Valvetrain[/TD]
[TD]
DOHC
[/TD]
[/TR]
[TR="class: b1"]
[TD]Position of cylinders[/TD]
[TD]
Inline
[/TD]
[/TR]
[TR="class: b0"]
[TD]Number of cylinders[/TD]
[TD]
4
[/TD]
[/TR]
[TR="class: b1"]
[TD]Bore[/TD]
[TD]
87 mm.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Stroke[/TD]
[TD]
92 mm.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Compression ratio[/TD]
[TD]
18
[/TD]
[/TR]
[TR="class: b0"]
[TD]Number of valves per cylinder[/TD]
[TD]
4
[/TD]
[/TR]
[TR="class: b1"]
[TD]Fuel Type[/TD]
[TD]
Diesel
[/TD]
[/TR]
[TR="class: b0"]
[TD]Wheel Drive[/TD]
[TD]
Front wheel drive
[/TD]
[/TR]
[TR="class: b1"]
[TD="width: 40%"]Number of Gears (automatic transmission)[/TD]
[TD="width: 60%"]
5
[/TD]
[/TR]
[TR="class: b0"]
[TD]Number of Gears (manual transmission)[/TD]
[TD]
6
[/TD]
[/TR]
[TR="class: b1"]
[TD]Front suspension[/TD]
[TD]
The depreciated rack
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Rear suspension[/TD]
[TD="width: 60%"]
Helical spring
[/TD]
[/TR]
[TR="class: b1"]
[TD]Front brakes[/TD]
[TD]
Ventilated discs
[/TD]
[/TR]
[TR="class: b0"]
[TD]Rear brakes[/TD]
[TD]
Disc
[/TD]
[/TR]
[TR="class: b1"]
[TD]ABS[/TD]
[TD]
yes
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Steering type[/TD]
[TD="width: 60%"]
Steering rack
[/TD]
[/TR]
[TR="class: b1"]
[TD]Power steering[/TD]
[TD]
Hydraulic Steering
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Fuel consumption (economy) - urban[/TD]
[TD="width: 60%"]
8.5 l/100 km.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Fuel consumption (economy) - extra urban[/TD]
[TD]
5.2 l/100 km.
[/TD]
[/TR]
[TR="class: b0"]
[TD]Fuel consumption (economy) - combined[/TD]
[TD]
6.4 l/100 km.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Kerb Weight[/TD]
[TD]
1525 kg.
[/TD]
[/TR]
[TR="class: b0"]
[TD="width: 40%"]Max. weight[/TD]
[TD]
2075 kg.
[/TD]
[/TR]
[TR="class: b1"]
[TD]Tire size[/TD]
[TD]
205/55 R16
[/TD]
[/TR]
[TR="class: b0"]
[TD]Wheel rims size[/TD]
[TD]
R16[/TD]
[/TR]
[/TABLE]
