- 2 May 2016
Forumda arattım ama bulamadım, Faz 2 85 BG lerin internette türkçe sitelerde teknik verilerini bulamadım Faz 1 80 Bg ler çıkıyor, bende ingilizce bulduğum kaynağı paylaşayım dedim
http://www.autoevolution.com/cars/r...l#aeng_renault-megane-sedan-2006-15-dci-85-hp
Araç ağırlığı yanlış galiba olması gereken boş ağıırlık 1280 KG
[h=3]RENAULT Megane Sedan 1.5 dCi (85 HP) - technical specs[/h][h=3]ENGINE SPECIFICATIONS[/h]CYLINDERSL4DISPLACEMENT1461 cm3POWER63 KW @ 3750 RPM
85 HP @ 3750 RPM
84 BHP @ 3750 RPMTORQUE148 lb-ft @ 1900 RPM
201 Nm @ 1900 RPMFUEL SYSTEMCommon RailFUELDieselCO2 EMISSIONS120 g/km
[h=3]PERFORMANCE SPECIFICATIONS[/h]TOP SPEED108.7 mph OR 175 km/hACCELERATION 0-62 MPH (0-100 KPH)12.8 s
[h=3]FUEL CONSUMPTION SPECIFICATIONS[/h]CITY42.8 mpg US OR 5.5 L/100KmHIGHWAY58.8 mpg US OR 4 L/100KmCOMBINED52.3 mpg US OR 4.5 L/100Km
[h=3]TRANSMISSION SPECIFICATIONS[/h]DRIVE TYPEFront Wheel DriveGEARBOXManual, 5 Speed
[h=3]BRAKES SPECIFICATIONS[/h]FRONTVentilated DiscsREARDiscs
[h=3]TIRES SPECIFICATIONS[/h]TIRE SIZE195/65R15
[h=3]DIMENSIONS SPECIFICATIONS[/h]LENGTH177.2 in OR 4501 mmWIDTH70.1 in OR 1781 mmHEIGHT57.5 in OR 1461 mmFRONT/REAR TRACK59.8/59.4 in OR 1,519/1,509 mmWHEELBASE105.9 in OR 2690 mmGROUND CLEARANCE4.7 in OR 119 mmCARGO VOLUME11.7 cuFT OR 331 LCD-
[h=3]WEIGHT SPECIFICATIONS[/h]UNLADEN WEIGHT2601.5 lbs OR 1180 kgGROSS WEIGHT LIMIT3902.2 lbs OR 1770 kg
Read more: http://www.autoevolution.com/cars/renault-megane-sedan-2006.html#ixzz48chKoBTS
85 HP @ 3750 RPM
