ApSUVai
Ekipmanlar:
Titan billet main caps
-ARP main studs
-Carillo H beam kollar
-Titan motorsports Custom piston set
-ARP 1/2" kapak saplamaları
-Power enterprise yatak seti
-Boostlogic üst kapak contası
-Ferrea Competition Plus Valves
-Ferrea Valve Springs
-Ferrea Titanium Retainers
-Ferrea Spring Seat Locator
-Ferrea Valve Locks
-Ferrea Valve Stems Seals
-HKS Cam Gears
-HKS 264 Camshafts
-HKS Timing Belt
-Titan Motorsports Billet Timing Belt Tensioner
-Greddy Pulley Set
-Greddy emme manifoldu
-Hypertune 90mm gaz kelebeği
-Fullrace turbo manifold
-Garrett bb gt4094 t4 divided turbo. ( şanzımanı düze geçene kadar)
-Boostlogic Supra TT Oil Feed and Return Kit
-Titan motorsports triple fuel pump system
-HKS oil cooler
-HKS hypermax coilover set
-AEM Water Methanol Injection Kit - 5 GAL
-Boost Logic Torque Converter by 3800 Stall
-Spal 7.5" Pull Fan For Auxillary Cooler
-9 Passage Transmission Oil Cooler 18x8.75x1
-R2 Racing Front Control Arm Bushing Kit
-R2 Racing Rear Control Arm Bushing Kit
-Samco Hose Kit
-TRD Low Temp Thermostat
-Koyo Radiator 53mm
-AEM 5 Bar Map Sensor
-AEM Intake Temp Sensor
-AEM EMS Gen 2 Ecu
-AEM Wideband
-HKS DLI
-HKS Radiator Cap
-MVP Motorsports Lexan Spark Plug Cover
-TRD Motor Mounts
-TRD Oil Filter Cap
-TRD 10,000 RPM Tach
-TRD 320 km/h Speedometer
-TRD LSD w/Installation kit and all Bearings need
Bu resim forum düzeni için küçültürmüştür. Orjinal boyut için buraya tıklayın.
-ARP main studs
-Ferrea Valve Locks
-HKS Cam Gears
-HKS 264 Camshafts
-HKS Timing Belt
-Greddy Pulley Set
-HKS oil cooler
-Samco Hose Kit
-Koyo Radiator 53mm
-AEM EMS Gen 2 Ecu
-AEM Wideband
-HKS DLI
-HKS Radiator Cap
-TRD Motor Mounts
-TRD Oil Filter Cap
