link uçmuş. yeniden paylaşım yapılabilir mi ?
Kaynak dil: İngilizce · Bu mesajı çevir
Prerequisites
To be able to install any custom package, it's mandatory to patch the iGO partition of your R-LINK 2 in order to unlock it.
This operation is low risk and completely reversible if you follow the instructions below and don't use a poor quality USB stick.
  1. From your R-LINK 2, retrieve your software release by going to Menu => Next page (page 2) => System Information => Software release
    Information about R-LINK 2 versions : https://www.gps-rlink.com/r-link-2/update-software/
  2. Download below the version corresponding to your software release :
    2.2.19.30x : mm2014_upgrade_igo_221930x_patched.zip (32,3 Mo)
    3.3.16.96x : mm2014_upgrade_igo_331696x_patched.zip (36,0 Mo)
    3.3.16.98x : mm2014_upgrade_igo_331698x_patched.zip (36,0 Mo)
    7.0.24.13x or 16x : mm2014_upgrade_igo_70241xx_patched.zip (45,3 Mo)
    8.0.32.50x : mm2014_upgrade_igo_803250x_patched.zip (49,5 Mo)
    9.0.33.43x : mm2014_upgrade_igo_903343x_patched.zip (57,9 Mo)
    9.0.34.61x : mm2014_upgrade_igo_903461x_patched.zip (57,7 Mo)
    Info: Like any official update of the R-LINK 2, installing one of these partitions will delete your address book and navigation history.
  3. Extract the R-LINK folder from the downloaded archive, and place it at the root of your USB stick.
  4. In your car (engine running), plug in the USB stick and after a few seconds, press Yes when the message asks you to install a software update.
    After the update, the R-LINK 2 will restart and remain on a black screen for 1 to 2 minutes. Don't panic, this is completely normal and wait for the R-LINK 2 interface to reappear.
  5. It's possible that the software update will be asked again, of course press No then disconnect USB stick and turn off the engine.
  6. Congratulations, your R-LINK 2 is now unlocked and ready to install any custom map package.
    Note: If you update your R-LINK 2 to a new version, you will return to the original iGO partition. So you will have to repeat the operation by selecting the corresponding version.
    Make sure that the version is present before updating your R-LINK 2 or you will no longer be able to use your custom maps.
Back to the original iGO partition
If for any reason, you want to restore the original iGO partition. Download below the version corresponding to your software release and follow the instructions above.
2.2.19.30x : mm2014_upgrade_igo_221930x_original.zip (41,4 Mo)
3.3.16.96x : mm2014_upgrade_igo_331696x_original.zip (53,8 Mo)
3.3.16.98x : mm2014_upgrade_igo_331698x_original.zip (53,7 Mo)
7.0.24.13x or 16x : mm2014_upgrade_igo_70241xx_original.zip (62,3 Mo)
8.0.32.50x : mm2014_upgrade_igo_803250x_original.zip (57,8 Mo)
9.0.33.43x : mm2014_upgrade_igo_903343x_original.zip (57,9 Mo)
9.0.34.61x : mm2014_upgrade_igo_903461x_original.zip (57,7 Mo)
You will then have to reinstall an official Renault map (only if you have installed a custom one) by downloading it from the official Renault tool: R-LINK2 Toolbox.
Paylaşayım istedim :)
Bi önceki link 6gb boyutundaydı. Bu dosya 350 mb. Bi yanlışlık olmasın.
6 gb tüm Avrupa bu sadece Türkiye, Kıbrıs vs sorun yok kardeşim.
Bu 350mb de 3d lerde varmi icinde ?
Arkadaşlar sizler nasıl bir şeysiniz. Yanlış anlamayınız ne kadar mükemmel insanlarsınız. Herkes birbirine yardımcı oluyor ve soruları cevaplayıp, sorunları çözüyor.
Herkesin emeklerine sağlık. Ben de sizlere çok teşekkür etmek istiyorum. Tüm yazılanları okudum. Linklerden gerekli indirmeleri yaptım. İlk fırsatta güncellemeyi uygulayacağım.
Bu arada aracım 2017 Megane 4 HB 8.7".
Ben de bir şey sormak istiyorum arkadaşlar. Benim araçtaki yazılım 3.3.16.986. Bu versiyondan başka versiyona güncellemeye izin vermiyor. Yabancı sitedeki tabloya göre.
Ben de şöyle bir şey mümkün mü diye merak ediyorum. Önce uygun versiyon 2'ye orjinal dosya ile dönüp ondan sonra v8 veya v9 a güncelleme yapabilir miyim.
Şimdiden herkese teşekkürler, selamlar, sağlıklı günler...
benimde clio 3 aracaımda tom tom varve arabayı yeni aldım sd kartı ve kumandası yok acaba bir sd kart edinsem bir harita yükleme yapabilirmiyim
