Agalar Şu Citro'yu Flash'la Karşılaştırırmısınız?
ÖzgürYaşam
sıfır zamanlarında binmişliğim var o zamanlar süperdi ama flash herzaman piyasası olan bir makine abi , sende değerini biliyorsun ben olsam düşünmem bile kıyaslamayı...
Eyvallahta bu makinanın gücü nedir onu merak ediyorum?direksiyon 3 kademe diye aklımda kalmış?yol tutuşu sanıyorum mükemmeldir?direksiyon hidrolik olmalı?0-100'ü nasıl acaba?kafa kafaya girsek omu beni yer benmi onu acaba?vs vs vs:)
ÖzgürYaşam
[h=2]992 CITROEN BX 15 TGE
[/h]Data for CITROEN BX 15 TGE, manufactured or sold in 1992, version for Europe (until middle 1992) with 5-door hatchback body type, FWD (front-wheel drive) and manual 5-speed gearbox. Basic specs and characteristics: petrol (gasoline) engine of 1580 cm3 / 96.4 cui displacement with advertised power 59 kW / 79 hp / 80 PS ( DIN ) / 5600 and 132 Nm / 97 lb-ft / 3000 of torque. Dimensions: this model outside length is 4237 mm / 166.8 in, it’s 1682 mm / 66.2 in wide and has wheelbase of 2655 mm / 104.5 in. The officially claimed value of a drag coefficient Cd = 0.34 . Standard wheels were fitted with tires size 165/70 SR 14. Reference vehicle weights are: official base curb weight 950 kg / 2094 lbs, gross weight GVWR 1445 kg / 3186 lbs. How fast is that car ? Performance: top speed 170 km/h (106 mph) (declared by factory); accelerations 0- 60 mph 13.2 s, 0- 100 km/h 13.8 s (declared by factory), 1/4 mile drag time (402 m) 17.8 s (a-c simulation). Fuel consumption and mileage: official: 7.3 l/100km / 38.5 mpg (imp.) / 32.2 mpg (U.S.) / 13.6 km/l , average estimated by a-c: 8.5 l/100km / 33.3 mpg (imp.) / 27.7 mpg (U.S.) / 11.8 km/l . To view table with this car complete performance data and technical specifications (including final drive and gear ratios, powertrain description, inside and outside dimensions, acceleration graphs etc.) and more photos, or to compare up to 5 cars side-by-side - click one of the the buttons below:
ÖzgürYaşam
bulabildiklerim inşallah yeterlidir abi yoksa araştırmaya devam :)
Şaşırtıcı değerler girsekmi bir kumara ne yapsak:)
MatraX_07
27 Mar 2011
Reıs bu arac plakası yenı yanı bu demektırkı arac dısarıdan gelmıs demektır arac fena degıl ama sen arabana bın :)
Hidrolik amortisör olması lazım bu araçlarda,yolda basabiliyorsun sınırları dahilinde,bozuk yollarda Kangoo dan bile yüksek oluyordu,çok dengeli bir yol tutuşu var bunların...
birde yedek parçası ve motorunun neler yapabileceği hakkında bilgi alabilsem fena taktım kafayı buna
Yedek parça sıkıntısı yaşayabilirsin,kilosuna göre motor gücü fena değil ancak senin aracınla kıyaslamaman gerekir,konfor ve yol tutuş istiyorsan bu araba 2 gömlek üstündür Flash dan...
