otoahmet
Megane 3 2014 1.5 dci 110 hp P0234 P2263 hataları
megene_3_gtline_2014siyah
16-Bursa
17 Mar 2026
Merhaba aşağıdaki kodları alıyorum. MAP sensörü ve turbo elektrovanasını değiştirdim düzelmedi. Sizce problemin kaynağı ne olabilir ? Araç 200binde, tüm bakımları zamanında otijinal parça ve orijinal rn720 kodlu yağ ile yapılıyor.
Car Scanner ELM OBD2
Version: 2.1.3/42001003/GP
DTC report
Connection profile: Renault Fluence, Grand Scenic III, Scenic III, Gran Tour III, Megane CC, Megane III 1.5 dCi K9K 832, K9K 836 [EN]Date: 11.03.2026 19:22:06
OBD-IIOBD-II
DTCs: 5
P0234 [0x0234]
Turbocharger (TC), engine boost condition - limit exceeded
Status: Confirmed
P0380 [0x0380]
Glow plugs, circuit A - malfunction
Status: Pending
P2263(21) [0x226321]
Turbocharger (TC) boost pressure/supercharger (SC) boost pressure - performance problem
Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
P1525(F3) [0x1525F3]
Air Bypass Valve System
Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear
P0380(96) [0x038096]
Status: Test failed, Pending, Test failed since last DTC clear, Test not completed during this operation cycle
Engine control unit (11 bit)Engine control unit (11 bit)
DTCs: 3
Odometer: 192386 km
Odometer: 192386 km
Odometer: 192371 km
ABS control unit (11 bit)
No DTC found.
SRS/Airbags (11 bit)SRS/Airbags (11 bit)
DTCs: 1
U3003(16) [0xF00316] Archive (inactive)
Battery voltage
Odometer: 192371 km
Aging counter: 8
Status: Confirmed, Test failed since last DTC clear
Power steering (11 bit)Power steering (11 bit)
DTCs: 4
U3003(13) [0xF00313] Archive (inactive)
Battery voltage
Odometer: 0 km
Aging counter: 32
Occurrence counter: 13
C1608(96) [0x560896] Archive (inactive)
Odometer: 192373 km
Aging counter: 32
Occurrence counter: 12
Battery voltage
Odometer: 192373 km
Aging counter: 29
Status: Confirmed, Test failed since last DTC clear, Warning indicator requested
C1608(49) [0x560849]
Odometer: 192373 km
Aging counter: 29
Occurrence counter: 0
Dashboard/Instrument cluster (11 bit)
No DTC found.
Bu turbo aktuatörünü gövdeye sabitleyen punta kaynaklarından kopmuş değiştirdim düzeldi ataba . Belki birinin işine yarar diye buraya yazıyorum.
    43.3 KB · Görüntüleme: 4
